Getting started with your Avolites product
Thank You For Choosing Avolites
We hope you’re happy with your new Avolites product. Now that you’ve got your hands on it, here’s a few tips and tricks to get yourself up and running.
To make setup as smooth as possible, have the following items available:
1. A USB Pen Drive is required for dedicated Avolites lighting consoles and media servers.
2. A computer with an Internet connection through a Local Area or Wi-Fi network (you may need the name and password of the network) or cellular data service through a carrier.
3. Your Avolites username and password; if you don’t have a username, you can create one here.
4. A beverage of your choice. 😉
https://www.avolites.com/app/uploads/2022/11/Image1.jpg
We hope you’re happy with your new Avolites product. Now that you’ve got your hands on it, here’s a few tips and tricks to get yourself up and running. In this section you will learn how to:
  • 1. Download the latest software
  • 2. Licence your new product
  • 3. Research our library of tutorials and guides
  • 4. Apply troubleshooting
Download The Latest Software
No matter what product line, find all the latest software versions Avolites offers for downloading. Please select the required software updates from the section below.
Ai
Download
T3 & A3+ Bundle
Titan PC Suite (software)
Download
Mobile
Download
Quartz
Download
Tiger Touch II
Download
Arena
Download
Sapphire Touch
Download
Diamond 9
Download
To avoid any issues when installing your new software updates please follow the below steps for each of our platforms.
Titan PC Suite
The Titan software requires the Microsoft .NET Framework v4.7 or latest to run, this will normally be installed on Windows 10 by default. For Windows 7 and 8.1 you may need to run Windows Update or download it from the Microsoft website.
Important: Please run the Titan PC Suite installer before plugging in your Avolites hardware to ensure that the drivers are installed correctly.
When installing Titan PC Suite, you are given the option to install Titan Mobile, Titan Simulator and Titan Go, if selected, these will appear as separate icons in the Start Menu. After the software has been installed, Titan Mobile and Titan Go require the hardware to be connected before the application can be used.
If the software does not recognise the hardware and displays the message ‘Dongle Not Found’, the firmware may need to be updated. The firmware can be updated by running USB Expert Console (C:\Program Files (x86)\Avolites\UsbExpert) then selecting [Update Now] from the Service tab.
The minimum and recommended PC specifications can be found here.
Titan Consoles
Please ensure you save and backup your shows before attempting to upgrade any software. Full instructions for upgrading both with an installer and a recovery stick are supplied with the download.
The installer upgrade procedure is reproduced briefly below:
  1. Save the software to the root directory of a USB stick or other storage device.
  2. Insert the USB stick in the console and select Control Panel > Titan Installers > Titan 15.1 Setup on the Tools menu.
  3. Follow the instructions presented by the installer, taking care to read each step carefully.
  4. Once the setup completes you need to restart the console. When the console restarts it should be updated to the new software; please check this by reading the version number in system mode.
The firmware can be updated by running USB Expert Console (Tools Menu > Control Panel) then selecting [Update Now] from the Service tab.
Ai
Ai will install by default to this location: C:\Avolites\Ai\Distrib
Ai can run from any directory, however it is always advised to keep the Distrib in this location and not rename it. It is also advised to store your project assets in the Distrib so they can easily be obtained for reference. The only example here is your media which is advised as being stored on a separate dedicated media drive.
Multiple instances of Ai can be installed at a time, all that is required is that the existing Distrib is renamed to something else. Before installing a new version of Ai it is advisable to rename or delete any existing Distrib folder before proceeding. Older files left over from a previous install can produce undesired effects when overwritten with a new install.
Renaming the folder is the safest option as nothing is destroyed and can also allow you to have multiple versions of Ai installed.
Help With Licensing
You may be required to licence your product before you can start using the software. Check out the quick tutorial to guide you through the process.
Quick Start Videos
Avolites offers a whole range of videos on how to use your product in the best possible way.
Download the latest Personalities
With over 20,000 fixtures our industry leading personality support has you covered. Click below to install the latest update. Download the latest Personalities.
https://www.avolites.com/app/uploads/2022/11/New-Project.jpg
Download Personalities
Troubleshooting
Ai
My screens are in the wrong order.
Go To FAQ
Ai
When I run Ai the screen is black.
Go To FAQ
Titan
How do I import custom or requested personalities?
Go To FAQ
Console Hardware
How do I set/change my consoles IP Address?
Go To FAQ
Can't find what you're looking for?
Speak to one of our team today
Titan Support +44 (0) 208 965 8522 (9:00am – 5:00pm UK)+44 (0) 7831 178 888 (Emergency Out of Hours) This hotline is for emergencies only and is available until 11 PM UK time. support@avolites.com
Ai Support +44 (0) 208 965 8522 (9:00am – 5:00pm UK)+44 (0) 7741 903 113 (Emergency Out of Hours) This hotline is for emergencies only and is available until 11 PM UK time. support@avolites.com
Still Have Questions?
For further assistance or manufacturer support, please email support@avolites.com. This email is monitored during business hours, Monday to Friday, from 9 AM to 5 PM. For general inquiries, please use our contact form. Open a ticket
Report a software bug
Open a ticket or Report a software bug Open a ticket
