Support » Troubleshoooting Installation from 3.5in Disk Register  Login
 Things to try if a program fails to load from a 3.5in floppy disk Minimize
  • Use a newly formatted disk. Format it on a PC using the FULL format not the quick method, or better still but not always possible format the disk using a desk. Then copy the program onto this disk.
  • If the program only partly loads you may find you cannot restart your desk, in this case, enter the AVOS menu by placing a jumper on the AVOS link and powering up the desk. Afterwards, try burning the program again. (For the Diamond 2/3 the AVOS link can be found on the edge of the MAP card at the opposite end to the backplane connector. To set the AVOS link on the other desks, follow this link: FAQ:How to set the Program Links (Opens New Window).)
Copyright © 2012 Avolites Ltd.  |  Terms Of Use
